[Osgeo4w-trac] Re: [osgeo4w] #119: liblas Python does not install
liblas .dll into OSGeo4W\bin folder
trac_osgeo4w at osgeo.org
Tue Feb 9 16:04:56 EST 2010
#119: liblas Python does not install liblas .dll into OSGeo4W\bin folder
Reporter: williamskg6 | Owner: hobu
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Resolution:
Keywords: liblas, python |
Comment (by williamskg6):
Replying to [comment:2 hobu]:
> What happens if you choose to install the other liblas packages
(dev/bin)? Do things end up in the right spot? The dependency chain of
liblas' python bindings might not be correct.
Unfortunately, the fix I described above no longer works. Now I get an
error stating that LASHeader_GetProj4 is not found. I have tried
installing Proj4 and still get the same error. Any ideas?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/119#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
