[Osgeo4w-trac] Re: [osgeo4w] #134: Document osgeo-setup.exe
commandline options
trac_osgeo4w at osgeo.org
Tue Feb 16 22:43:37 EST 2010
#134: Document osgeo-setup.exe commandline options
Reporter: jmckenna | Owner: jmckenna
Type: task | Status: closed
Priority: minor | Component: Documentation
Version: | Resolution: fixed
Keywords: |
Changes (by jmckenna):
* status: new => closed
* resolution: => fixed
Comment:
Ok thanks Frank. I have documented the options at
http://trac.osgeo.org/osgeo4w/wiki/CommandLine
Note that if I try -h with the original cygwin setup.exe the output is
sent correctly to the Command window, and also to setup.log.full (our
installer does not send the ouput to the Command window).
-jeff
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/134#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
