[Osgeo4w-trac] [osgeo4w] #136: apt doesn't install dependencies
	first
    trac_osgeo4w at osgeo.org
    Wed Feb 17 16:31:07 EST 2010
#136: apt doesn't install dependencies first
Reporter:  maphew  |       Owner:  maphew
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Installer
 Version:          |    Keywords:  apt
 `apt install shell` will correctly grab the pre-req `msvcrt`, but it
 installs `shell` first, consequently the required xxmklink.exe is not
 available to create the menu and desktop links.
 Curiously the install order is independent of order on command line, `apt
 install msvcrt shell` will still attempt shell first.
 Work-around: `apt install shell && apt remove shell && apt install shell`
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/136>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
