[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
trac_osgeo4w at osgeo.org
Tue Mar 16 13:32:28 EDT 2010
Reporter: lutra | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal, gdal utilities |
Comment (by mwtoews):
Replying to [comment:5 jef]:
> Could you run [[http://www.dependencywalker.com/ depends]] on
{{{%OSGEO4W_ROOT%/apps/gdal-16/pymod/osgeo/_gdal.pyd}}}?
I did this on both an XP system, with only a few warnings, and with Win7
x64 with errors. My result is a 3.5MB file -- too big to upload on this
Trac system. (I can upload or email this file on request: append
@gmail.com to my username).
Here are my exact steps from an OSGeo4W Shell on the Win7 x64 system:
C:\>gdal16
C:\>SET GDAL_DATA=C:\OSGeo4W\apps\gdal-16\share\gdal
C:\>SET GDAL_DRIVER_PATH=C:\OSGeo4W\apps\gdal-16\bin\gdalplugins
C:\>SET PYTHONPATH=C:\OSGeo4W\apps\gdal-16\pymod;C:\Program Files
(x86)\ArcGIS\b
in
C:\>PATH=C:\OSGeo4W\apps\gdal-
16\bin;C:\OSGeo4W\bin;C:\Windows\system32;C:\Windo
ws;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Pytho
n25;C:\Python25\Scripts;C:\Program Files
(x86)\PostgreSQL\8.3\bin;C:\Program Fil
es (x86)\QuickTime\QTSystem\;C:\Program
Files\TortoiseSVN\bin;C:\Users\mobile20\
AppData\Local\Start++\LNKs;C:\Users\mobile20\AppData\Local\Start++\CMDs;C:\OSGeo
4W\apps\msys\bin
C:\>depends OSGeo4W\apps\gdal-16\pymod\osgeo\_gdal.pyd
The Dependency Walker log details:
> Error: At least one module has an unresolved import due to a missing
export function in an implicitly dependent module.[[BR]]
> Error: Modules with different CPU types were found.[[BR]]
> Warning: At least one delay-load dependency module was not found.[[BR]]
> Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
