[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 16 17:05:46 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by lutra):
 > Ah ok, you're not running from the OSGeo4W shell.  If you use the
 "standard" command
 > prompt you need to run {{{o4w_env.bat}}} to setup the environment for
 OSGeo4W.  Without it {{{%OSGEO4W_ROOT%}}} is unset and {{{gdal16.bat}}}
 won't set proper paths.
 new log attached.
 The gdal python commands issued from the osego4w shell are working this
 way. I see no changes when issuing the same one from the gdal tools plugin
 (qgis launched from the very same osgeo4w shell)
 File "C:\OSGeo4W\apps\gdal-16\bin\gdal_proximity.py", line 35, in
 import gdal
 ImportError: No module named gdal
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:14>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
