[Osgeo4w-trac] Re: [osgeo4w] #178: QGIS 1.5/dev does not start
anymore under XP + 64bit issues
trac_osgeo4w at osgeo.org
Thu Sep 9 13:41:28 EDT 2010
#178: QGIS 1.5/dev does not start anymore under XP + 64bit issues
Reporter: lutra | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Keywords:
Comment(by lutra):
> when it comes to choose what packages/libraries to install, the
installer does not marks automatically the dependencies, so it makes very
hard to make a correct installation.
this problem does not appear when installing osgeo4w under Seven 64bit
> I miss to test how it works under Windows Seven 64bit, test that I will
do in the next hours.
it works fine, no problems at all, as under Seven 32 bit.
I'm puzzled about the situation under Windows XP. In all the machines I
tested I'm experiencing the above problems (never seen before... and I've
installed qgis hundred of times), while I've been told by another person
that it seems to still install/work fine.
I believe/suggest more tests under XP.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/178#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
