[Osgeo4w-trac] Re: [osgeo4w] #181: gpsbabel: missing libexpat XML parsing support (GPX)
OSGeo4W trac_osgeo4w at osgeo.org
Mon Dec 5 13:03:30 EST 2011
Reporter:  hamish              |        Owner:  osgeo4w-dev@…
    Type:  defect              |       Status:  closed
Priority:  major               |    Component:  Package
 Version:                      |   Resolution:  fixed
Keywords:  gpsbabel, wingrass  |
Changes (by maphew):
  * status:  new => closed
  * resolution:  => fixed
Old description:
> Hi,
> osgeo4w's build of gpsbabel is not working on GPX files, which is a major
> (the primary?) reason for shipping gpsbabel in the first place. the error
> message when you try to use it is:
> GPX: This build excluded GPX support because expat was not installed.
> see also #9 and #171, and the GRASS version of this bug:
>   https://trac.osgeo.org/grass/ticket/1171
> tested in a GRASS 6.5svn nightly wingrass build from the last week.
> thanks,
> Hamish
New description:
 see also #59 and #171, and the GRASS version of this bug:
 thanks,
 Hamish
Comment:
 confirmed, gpsbabel does not report this error anymore.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/181#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
