[Osgeo4w-trac] Re: [osgeo4w] #208: OSGeo4w shell: Environment not
 set correctly to use python with qgis bindings
    trac_osgeo4w at osgeo.org
    Thu Jan 27 09:17:10 EST 2011
#208: OSGeo4w shell: Environment not set correctly to use python with qgis
bindings
Reporter:  milovanderlinden           |        Owner:  osgeo4w-dev@…
    Type:  defect                     |       Status:  closed
Priority:  major                      |    Component:  Installer
 Version:                             |   Resolution:  worksforme
Keywords:  install shell qgis python  |
Changes (by jef):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Replying to [comment:1 milovanderlinden]:
 > Solution I took:
 > 1. Add a qgis.bat file in the directory: %OSGEO4W_ROOT%\etc\ini
 > 2. Put this as content in the file:
 > SET PYTHONPATH=%OSGEO4W_ROOT%\apps\qgis\python
 > PATH=C:\OSGeo4W\apps\qgis\bin;%PATH%
 A better option would be to create a batch file like {{{qgis.bat}}} to
 start the application that is using {{{qgis.core}}}.   Adding a
 {{{qgis.bat}}} to {{{etc/ini}}} might interfere with install of multiple
 qgis versions.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/208#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
