[Osgeo4w-trac] Re: [osgeo4w] #199: multiple GDAL versions used
trac_osgeo4w at osgeo.org
Sun Jan 30 05:26:36 EST 2011
Reporter: msieczka | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: trivial | Component: Package
Version: | Resolution: wontfix
Keywords: |
Changes (by jef):
* priority: major => trivial
* status: reopened => closed
* resolution: => wontfix
Comment:
Replying to [comment:2 msieczka]:
> Replying to [comment:1 jef]:
> > The output in the about box is wrong. QGIS is using GDAL 1.7.
> Can the dialog be fixed then? On my Linux installations, and the OSGeo4W
1.7.0 one, the build-time and run-time GDAL versions match. Only the
OSGeo4W 1.6.0 install claims it was built against 1.5, while running
against 1.7.
This is kind of a non-issue. Everything works fine and it's using GDAL
1.7. I won't rebuild QGIS 1.6 just to get the about box right. This
will solve itself with the next release.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/199#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
