[Osgeo4w-trac] Re: [osgeo4w] #34: proj: projects.h missing
trac_osgeo4w at osgeo.org
Sat Mar 26 23:13:14 EDT 2011
Reporter: jef | Owner: warmerdam
Type: defect | Status: closed
Priority: minor | Component: Package
Version: | Resolution: fixed
Keywords: pkg-proj |
Comment(by hamish):
Replying to [comment:9 martinl]:
> Replying to [comment:8 hamish]:
> > ok; to avoid mass breakage I'd request that we coordinate
> > releasing GRASS 6.4.1 with this problem fixed before releasing
> > a new version of PROJ.4 with the header removed.
> what's the status?
in proj4: see https://trac.osgeo.org/proj/ticket/98
in grass: experimental patch applied in 6.5svn and trunk, see
https://trac.osgeo.org/grass/changeset/45469
in osgeo4w: as jef points out in comment:10 the missing file shouldn't be
missing any more (caveat, see proj4 bug # 98), so is the current failure
due to a stale osgeo4w install on the wingrass nightly build server, or..?
do the 6.5svn and trunk builds work?
best,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/34#comment:13>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
