[Osgeo4w-trac] Re: [osgeo4w] #219: Upgrade python version
trac_osgeo4w at osgeo.org
Mon May 2 15:05:28 EDT 2011
Reporter: jmalik | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Keywords: python
Comment(by maphew):
I've built a python 2.7 package for testing,
while osgeo.org is down you can fetch it here:
http://files.environmentyukon.ca/matt/python-2.7.1-1.tar.bz2
It *REPLACES* the existing python2.5 files:
.\bin\python.exe
.\bin\pythonw.exe
.\bin\w9xpopen.exe
.\etc\ini\python.bat
So make a backup of these 4 files if you're testing in an existing
install. Everything else is untouched (e.g. .\apps\python25).
To use, unpack from `%osgeo4w_root%`.
My install and testing procedure:
1. Download standalone apt from
http://code.google.com/p/maphew/downloads/list and place in PATH as
apt.exe.
2. Open command shell and
set osgeo4w_root=c:\o4w_py27
apt setup
:: to share cache with existing install
:: and avoid needless downloads
REM copy c:\osgeo4w\etc\setup\last-cache %osgeo4w_root%\etc\setup\
apt install shell
:: install py27 testing package, assumes 7zip in path
pushd %osgeo4w_root%
7z x python-2.7.1-1.tar.bz2
3. Run osgeo4w.bat
You now have a minimal osgeo4w install with just shell and python 2.7. Use
apt to install other packages and see what works/breaks.
Remember to open a new OSGeo4W shell after installing (or run the batch
files in .\etc\ini manually).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/219#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
