[Osgeo4w-trac] [osgeo4w] #239: GRASS 6.4.2RC1 does not work under QGIS (and causes crashes)
OSGeo4W trac_osgeo4w at osgeo.org
Wed Oct 19 08:10:24 EDT 2011
Reporter:  lutra    |       Owner:  martinl
    Type:  defect   |      Status:  new
Priority:  blocker  |   Component:  Package
 Version:           |    Keywords:
 Since GRASS in osgeo4w has been updated to 6.4.2 it is available only in
 qgis-dev.
 When running qgis-dev the GRASS plugin seems to work fine, this is the
 result of g.version from the GRASS console
 GRASS 6.4.2RC148715M (2011)
 But when adding a vector the program throws
 Cannot get projection
 Cannot run module
 command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
 info=proj<br><br>ERROR: Incompatible library version for module. You need
 to rebuild GRASS
        or untangle multiple installations.
 and the vector is eventually added to the canvas.
 When adding a raster the message is the same, but this time the program
 keeps throwing it 2/3 times and then QGIS crashes.
 At this stage there is NO GRASS support under QGIS for Windows users.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/239>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
