[Osgeo4w-trac] Re: [osgeo4w] #53: pkg-apt: "apt [command]" with no
parameters does not return an error or message
trac_osgeo4w at osgeo.org
Thu Apr 5 02:11:58 EDT 2012
#53: pkg-apt: "apt [command]" with no parameters does not return an error or
message
Reporter: maphew | Owner: maphew
Type: defect | Status: closed
Priority: major | Component: Installer
Version: | Resolution: fixed
Keywords: apt |
Changes (by maphew):
* status: assigned => closed
* resolution: => fixed
Comment:
(In [1188]) close #53. All commands should now exit gracefully with msg if
incomplete.
def_version(): report version of named package instead of all versions;
moved reporting of all to def_versions(). There is overlap between this
and def_list() which also reports all versions, as well as possible
upgrades. FIXME: remove versions from def_list? would allow easier piping.
Ticket URL: </ticket/53#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
