[Osgeo4w-trac] [osgeo4w] #288: GDAL - Datum shift issue (WGS84, NAD27, NAD83)
OSGeo4W trac_osgeo4w at osgeo.org
Fri Apr 27 12:41:02 EDT 2012
Reporter:  tcgeophysics  |       Owner:  osgeo4w-dev@…
    Type:  defect        |      Status:  new
Priority:  major         |   Component:  Package
 Version:                |    Keywords:  Datum shift grids NAD27 proj
 Hi All,
 I am encountering a gdalwarp issue that I have a hard time narrowing
 down...
 I have a Canadian DEM (CDED) in USGS DEM format in Lat/Lon NAD83 (EPSG
 4269) and I want to convert it to an ER Mapper ERS format in UTM Zone 16
 NAD27 (EPSG 26716).
 The command I use is the following:
 > gdalwarp -s_srs EPSG:4269 -t_srs EPSG:26716 -of ERS 042c_0100_deme.dem
 042c_0100_deme_NAD27UTMZ16N.ers
 And the output is:
 > ERROR 1: No such file or directory
 > ERROR 1: GDALSuggestedWarpOutput() failed because the passed transformer
 failed.
 GDAL was installed using osgeo4w.exe installer on my Window 7 machine.
 After doing some research it seems that datum shift grids may not be built
 by default with Proj.4.
 Is there other dependencies that may affect datum shifts?
 How can I check that datum shift grids were built and which ones?
 What can be an approach to add other datum shift grids?
 Thanks
 Thomas
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/288>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
