[Osgeo4w-trac] [osgeo4w] #294: Recoding non-Latin characters with GDAL is not supported now.
OSGeo4W trac_osgeo4w at osgeo.org
Fri Aug 31 02:10:51 PDT 2012
Reporter:  akaginch            |        Owner:  warmerdam
    Type:  defect              |       Status:  closed
Priority:  major               |    Component:  Package
 Version:                      |   Resolution:  fixed
Keywords:  character recoding  |
Changes (by akaginch):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Thank you warmerdam.
 I've tested new gdal19.dll with ogr2ogr as below. The encoding of source
 shapefile is CP932 and the LDID is set to 19.[[BR]]
 {{{ogr2ogr -f KML test.kml test.shp}}}[[BR]]
 It has converted character encoding from CP932 to UTF-8 well.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/294#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
