[Osgeo4w-trac] [osgeo4w] #320: Transformation Problem with Merchich Sahara Projections
trac_osgeo4w at osgeo.org
Fri Nov 30 16:21:27 PST 2012
Reporter: ysid | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
When using cs2cs to transform into a Merchich Sahara projection (EPSG
26194 or 26195) in OSGeo4W v1.9.1, results can be incorrect. Results are
correct when no GDAL/PROJ/OSGeo variables are specified in the
environment, but are incorrect when specified. To be clear, I will
present an example:
Input coordinate:
* Projection: Geographic WGS84 (EPSG 4326)
* Proj4: +proj=longlat +datum=WGS84 +pm=greenwich +ellps=WGS84
* Coordinate: -16.6666666666667 18.6666666666667
Output coordinate:
* Projection: Merchich Sahara South (EPSG 26195)
* Proj4: +proj=lcc +units=m +towgs84=31,146,47,0,0,0,0 +pm=greenwich
+a=6378249.2 +b=6356515 +lon_0=-5.4 +x_0=1500000 +y_0=400000 +lat_0=22.5
+lat_1=22.5 +k_0=0.999616437
* Coordinate: 310159.282196 20443.0660249
Note: Instead of the "+b" value, an alternative "+rf" variable can be
specified, and will give results that are virtually identical (rf value is
293.466021293627).
The abovementioned coordinate is the correct value, as verified by the
website:
http://cs2cs.mygeodata.eu/
Similar results are also obtained in PCI and ArcGIS.
When running the above transformation using cs2cs, the following command
is used:
cs2cs.exe -f "%.03f%" +proj=longlat +datum=WGS84 +pm=greenwich
+ellps=WGS84 +to +proj=lcc +units=m +towgs84=31,146,47,0,0,0,0
+pm=greenwich +a=6378249.2 +rf=293.466021293627 +lon_0=-5.4 +x_0=1500000
+y_0=400000 +lat_0=22.5 +lat_1=22.5 +k_0=0.999616437 input.txt >
output.txt
The result depends on the environment setting. When no environment
setting specific to PROJ4 or GDAL are set, the results are correct.
However, when environment variables are set, the result is very wrong.
* Without environment settings: 310159.282 20443.066 -80.008
* With environment settings: 296432.545 39220.367 -80.008
Interestingly, the ellipsoidal height is the same in both cases.
Environment settings used are typical for an OSGeo4W/GDAL installation, as
folllows:
GDAL_DATA: <OSGeo4W_install_dir>\share\gdal
GDAL_DRIVER_PATH: <OSGeo4W_install_dir>\bin\gdalplugins\1.9
GEOTIFF_CSV: <OSGeo4W_install_dir>\share\gdal
OSGEO4W_ROOT: <OSGeo4W_install_dir>
PROJ_LIB: <OSGeo4W_install_dir>\share\proj
Strange results are also seen when using gdalwarp with the same from and
to projections and environment variables.
Something in the OSGeo4W installation is causing the coordinates to be
transformed incorrectly.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/320>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
