[Osgeo4w-trac] [osgeo4w] #307: OpenEV does not start because of Python error
OSGeo4W trac_osgeo4w at osgeo.org
Fri Oct 12 13:10:06 PDT 2012
Reporter:  jratike80  |        Owner:  osgeo4w-dev@…
    Type:  defect     |       Status:  closed
Priority:  major      |    Component:  Package
 Version:             |   Resolution:  wontfix
Keywords:  OpenEV     |
Changes (by warmerdam):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I see the same problem, but only if I run openev.bat within
 C:\OSGeo4W\bin.  If I run it somewhere else, I get proper behavior.  I
 believe that is because if you run it from within the bin directory the
 local DLLs take precidence over other special version DLLs required by
 OpenEV.  I don't forsee an easy way to fix this.
 On that basis I'm going to tentatively close this ticket, but I'm open to
 suggestions.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/307#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
