[Osgeo4w-trac] [osgeo4w] #304: Make installer administrative rights elevation optional.
    trac_osgeo4w at osgeo.org
    Sun Oct 21 20:27:35 PDT 2012
Reporter:  lpinner      |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  minor        |   Component:  Installer
 Version:               |    Keywords:
Comment(by lpinner):
 I've found a workaround! Documenting here for posterity.
 @echo off
 REM osgeo4w-setup-noelevation.bat
 set __COMPAT_LAYER=RUNASINVOKER
 start "" "osgeo4w-setup.exe"
 Note: my original request remains. This installer does not need UAC
 elevation by default.  If someone is experienced enough to install and
 configure a Windows service (such as Apache), then they're experienced
 enough to know how to right click on the installer and select "Run as
 administrator".
 Please change the manifest to "<requestedExecutionLevel level="asInvoker"
 uiAccess="false"/>"
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/304#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
