[Osgeo4w-trac] [osgeo4w] #305: sqlite/spatialite: "sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
trac_osgeo4w at osgeo.org
Sat Oct 27 11:47:09 PDT 2012
"sqlite3.dll"
Reporter: hellik | Owner: brushtyler
Type: defect | Status: new
Priority: critical | Component: Package
Version: 1.0 | Keywords: sqlite,spatialite
Comment(by brushtyler):
I've built the sqlite3.dll using mingw by {{{ ./configure
SQLITE_ENABLE_RTREE=1 --build=mingw32 --target=mingw32 }}} (though the
nmake.opt file I used the last time set SQLITE_ENABLE_RTREE=1 as well),
but running grass7-dev after copying the DLL in OSGeo4W/bin it still
raises the error.
In the traceback I see that grass7 uses python ctypes to load the DLL, so
I tried to do the same from OSGeo4W shell and using python ctypes I can
find the function within the DLL and load it.
So, are you sure the problem is not within the grass7 code?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/305#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
