[Osgeo4w-trac] [osgeo4w] #305: sqlite/spatialite: "sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
OSGeo4W trac_osgeo4w at osgeo.org
Sat Oct 27 12:18:49 PDT 2012
"sqlite3.dll"
Reporter:  hellik    |       Owner:  brushtyler
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:  1.0       |    Keywords:  sqlite,spatialite
Comment(by hellik):
 Replying to [comment:9 brushtyler]:
 > I've built the sqlite3.dll using mingw by {{{ ./configure
 SQLITE_ENABLE_RTREE=1 --build=mingw32 --target=mingw32 }}} (though the
 nmake.opt file I used the last time set SQLITE_ENABLE_RTREE=1 as well),
 > but running grass7-dev after copying the DLL in OSGeo4W/bin it still
 raises the error.
 > In the traceback I see that grass7 uses python ctypes to load the DLL,
 so I tried to do the same from OSGeo4W shell and using python ctypes I can
 find the function within the DLL and load it.
 > So, are you sure the problem is not within the grass7 code?
 thanks for your effort!
 but shouldn't it be the other way around, suggested by Sandro (see
 https://trac.osgeo.org/osgeo4w/ticket/305#comment:5):
 (disable/no SQLITE_ENABLE_RTREE in sqlite) and disable
 DISABLE_GEOMETRY_CALLBACKS in spatialite?
 Helmut
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/305#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
