[Osgeo4w-trac] [osgeo4w] #305: sqlite/spatialite: "sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
    trac_osgeo4w at osgeo.org
    Sat Oct 27 14:32:32 PDT 2012
"sqlite3.dll"
Reporter:  hellik    |       Owner:  brushtyler
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:  1.0       |    Keywords:  sqlite,spatialite
Comment(by hellik):
 Replying to [comment:19 brushtyler]:
 > Replying to [comment:18 hellik]:
 > > can you try '''DISABLE_GEOMETRY_CALLBACKS''' in '''spatialite'''?
 > yes, I can (and I'm doing it), but I guess this won't fix the problem.
 > BTW, in SpatiaLite 3.0.1 (the version shipped with OSGeo4W) the name of
 the flag is '''OMIT_GEOCALLBACKS''', probably it was changed to
 DISABLE_GEOMETRY_CALLBACKS in the last splite version.
 I've just done a ./configure --help in the libspatialite-3.0.1-source
 within the osgeo4w-msys:
 `configure' configures libspatialite 3.0.1 to adapt to many kinds of
 systems.
   --enable-geocallbacks   enables geometry callbacks [default=yes]
 maybe time to ask Sandro as developer of spatialite to avoid confusion
 (I'm a little bit)?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/305#comment:21>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
