[Osgeo4w-trac] [osgeo4w] #301: Problem running gdal*.py in osgeo4w	shell
    trac_osgeo4w at osgeo.org
    Mon Sep 10 03:24:13 PDT 2012
Reporter:  vascobnunes  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  osgeo4w, gdal
 I'm trying to run gdal_calc.py (and other gdal*.py) from the Osgeo4w shell
 and can't do it cause I get this error:
 C:\>gdal_calc
   File "C:\OSGeo4W\\bin\gdal_calc.py", line 47, in <module>
     import gdal
   File "C:\OSGeo4W\apps\Python27\lib\site-packages\gdal.py", line 2, in
 <module>
     from osgeo.gdal import deprecation_warn
   File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py",
 line 21,
 in <module>
     _gdal = swig_import_helper()
 line 17,
 in swig_import_helper
     _mod = imp.load_module('_gdal', fp, pathname, description)
 ImportError: DLL load failed: The specified procedure could not be found.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/301>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
