[Osgeo4w-trac] [osgeo4w] #42: SDE Driver : MSVCP71D.dll (debug)	dependency
    trac_osgeo4w at osgeo.org
    Sun Apr  7 19:33:34 PDT 2013
Reporter:  mwtoews         |        Owner:  hobu
    Type:  defect          |       Status:  reopened
Priority:  major           |    Component:  Package
 Version:                  |   Resolution:
Keywords:  pkg-gdal-sde92  |
Changes (by mwtoews):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 This is still a current issue with gdal-sde92 version 1.5.0-1.
 http://lists.osgeo.org/pipermail/osgeo4w-dev/2013-April/002169.html
 Depends on gdal_SDE.dll/ogr_SDE.dll shows dependence on:
  * GDAL15.DLL (provided by OSGeo4W, in bin directory)
  * SDE.DLL (user supplied, along with PE.DLL and SG.DLL)
  * MSVCP71D.DLL
  * MSVCR71D.DLL
 The last two, as stated before, are debug run-time libraries. This needs
 to be recompiled as a release target instead, with dependencies on the the
 existing msvc[pr]71.dll files that are redistributed with OSGeo4W.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/42#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
