[Osgeo4w-trac] [osgeo4w] #358: Cannot start QGIS from OSGeo4W terminal - qgis_core.dll is missing
OSGeo4W trac_osgeo4w at osgeo.org
Thu Apr 25 15:04:36 PDT 2013
Reporter:  saultdon  |        Owner:  osgeo4w-dev@…
    Type:  defect    |       Status:  reopened
Priority:  major     |    Component:  Package
 Version:            |   Resolution:
Keywords:            |
Comment(by saultdon):
 Replying to [comment:5 jef]:
 > Replying to [comment:4 saultdon]:
 > > I use to be able to just type qgis into the terminal and it would
 start qgis (where it would call qgis.bat) but now it doesn't and the
 terminal defaults to the .exe calling qgis.exe I guess.
 > I'd just type qgis.bat.
 I know =P
 But I'd really like to be able to just type "qgis" like all the other
 applications can be launched using their shortnames.
 If I type qgis.bat and let that run qgis the first time, and keep the
 terminal open, the env vars are set fine and I can then successfully
 launch qgis again using just qgis without the .bat extension.
 I have to re-load the vars from qgis.bat by running qgis.bat when ever the
 terminal is closed then opened again.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/358#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
