[Osgeo4w-trac] [osgeo4w] #358: Cannot start QGIS from OSGeo4W terminal - qgis_core.dll is missing
trac_osgeo4w at osgeo.org
Thu Apr 25 15:44:10 PDT 2013
Reporter: saultdon | Owner: osgeo4w-dev@…
Type: defect | Status: reopened
Priority: minor | Component: Package
Version: | Resolution:
Keywords: |
Changes (by saultdon):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:9 jef]:
> putting the stuff into etc/ini won't work as the settings for different
qgis version would conflict - that's why the batch files are there.
> That it changed is because qgis.exe was moved to the main bin, because
that makes it use DLLs existing there even if a different version exists
in system32 (ie. python27).
> And now qgis.exe and qgis.bat both live in the same directory.
> A note in [[wiki:pkg-qgis]] was added.
What about actually fixing it though? That "note" on that page is hidden
from users running the osgeo4w terminal - ie, they won't see it! I've
never even been to that page before you linked to it here.
Looks like this file/folder re-design actually broke something, or that
note needs to be placed in the osgeo4w terminal to be obvious to end-
users.
I don't think they will run to that page when they see the error when
trying to launch qgis from the terminal or are even reading that page
beforehand to learn how to run qgis from osgeo4w (b/c the terminal tells
you to type qgis).
For an end-user, qgis will appear broken... I know a developer knows what
to do and other technical users, but that doesn't help end users.
You need to look at this from an end-user perspective =)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/358#comment:10>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
