[Osgeo4w-trac] [osgeo4w] #398: Unable to connect to PostgreSQL DB in GRASS 7.0svn on Win 7
trac_osgeo4w at osgeo.org
Sat Dec 14 09:18:02 PST 2013
Reporter: GG1234 | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: minor | Component: Package
Version: | Keywords:
Comment(by GG1234):
Well, that one was short : it seems the problem arise because Win7 doesn't
allow to create folders with an initial ".". I manually added it with a
workaround found on "superuser.com" : put an initial AND a final "." like
this : ".grass7." in Windows Explorer. Windows will accept it and delete
the final dot.
Then the PG connection commands worked fine.
It might be usefull to add this in the osgeo4w installer ?
Should I therfore set the ticket to fixed ?
Thanks,
Cev.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/398#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
