[Osgeo4w-trac] [osgeo4w] #339: OSGEO4W Installer doesn't work
trac_osgeo4w at osgeo.org
Fri Feb 8 10:18:37 PST 2013
Reporter: moreno | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: blocker | Component: Installer
Version: | Keywords: Installer OSGEO4W
Comment(by hellik):
Replying to [comment:2 maphew]:
> hmm. Works for me this morning. How did you retrieve the version #? I
don't see it. The one I downloaded this morning has a creation date of
"2011 March 02, 7:33:07 AM".
OSGeo4W installed some time ago.
today morning:
All Programms -> OSGeo4W -> Setup -> Advanced Install => there is an
updated OSGeo4W Installer/Setup available
> Possible difference between mine and yours: I have UAC turned off. Try
running setup with elevated admin privileges (r-click >> Run as
Administrator).
admin rights are elevated, this isn't the problem here.
could it be that accessing http://download.osgeo.org/osgeo4w/setup.ini is
causing this issue?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/339#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
