[Osgeo4w-trac] [osgeo4w] #366: osgeo4w qGis 1.8.0-9 installation fails for Spatialite4.dll not found
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jul 31 07:43:33 PDT 2013
Reporter:  francescomarucci  |       Owner:  osgeo4w-dev@…
    Type:  defect            |      Status:  new
Priority:  major             |   Component:  Installer
 Version:                    |    Keywords:  qgis 1.8.0-9
Comment(by esseffe):
 I've done a quick test, and I can confirm the problem reported by
 Francesco:
 - when installing 1.8.0-9 the spatialite package will not be automatically
 updated, thus causing a broken reference to spatialite4.dll
 - if you then manually update the spatialite package (or if you install
 the qgis-dev nightly build) then 1.8.0-9 will correctly start
 - anyway this 1.8.0-9 build is not able to connect any DB-file created
 using spatialite v4, because the CMake configuration wasn't updated as
 required before building on the top of spatialite4.dll
 bye Sandro
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/366#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
