[Osgeo4w-trac] [osgeo4w] #389: Matplotlib issue causing crash in ProfileTool plugin. "UnicodeDecodeError?: 'ascii' codec can't decode byte 0x8e in position 8: ordinal not in range(128) "
OSGeo4W trac_osgeo4w at osgeo.org
Tue Nov 5 00:04:51 PST 2013
range(128) "
Reporter:  nicolascadieux  |       Owner:  osgeo4w-dev@…
    Type:  defect          |      Status:  new
Priority:  major           |   Component:  Package
 Version:                  |    Keywords:  matplotlib, x86_64
Comment(by alexbruy):
 Just tested on two other computers with clean 64-bit Windows 7 install and
 64-bit OSGeo4W installer. There is no error. Maybe this is depends on some
 environment settings
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/389#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
