[Osgeo4w-trac] [osgeo4w] #397: FFTW misses import library
OSGeo4W trac_osgeo4w at osgeo.org
Tue Nov 19 02:42:14 PST 2013
Reporter:  jmalik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  fftw
Comment(by jef):
 Not sure how the 32bit fftw package was built.  But the build recipe for
 the 64bit built is in {{{x86_64/release/fftw/fftw-3.3.3-1-src.tar.bz2}}}.
 Note that it's built with MinGW - as GRASS is currently it's only
 dependant.   Could you try if https://wiki.videolan.org/GenerateLibFromDll
 also helps to building a working 64bit {{{.lib}}} from the fftw DLL?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/397#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
