[Osgeo4w-trac] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Sat Apr 5 11:57:56 PDT 2014
Reporter:  hellik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  R
 hi,
 there are some nice simple windows-bat files [1] [2] to start R
 (www.r-project.org) from everywhere if these bat-files are in %PATH%
 tested here locally with following example
 (A)
 batch files are in e.g.
 C:\OSGeo4W\apps\r-batchfiles
 (B)
 added a bat-file in
 C:\OSGeo4W\etc\ini\r-project.bat
 with a onliner to add (A) to the path
 PATH %PATH%;%OSGEO4W_ROOT%\apps\r-batchfiles
 then R is availabe in the OSGeo4W-shell/OSGeo4W-windows command shell and
 can be started e.g. within a winGRASS-session.
 as these R-batch-files recognizes R 32bit/R 64bit, it may be included in
 OSGeo4W 32bit and 64bit.
 the license is GNU GPL v2.
 it would be a really added value for OSGeo4W, as R is often used in GIS
 workflows/analyses and the OSGeo4W-R-integration would be enabled in an
 easy way.
 would it be possible these files into OSGeo4W?
 thanks
 Helmut
 [1] https://code.google.com/p/batchfiles/
 [2] http://cran.r-project.org/contrib/extra/batchfiles/
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/413>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
