[Osgeo4w-trac] [osgeo4w] #400: SAGA downgrades to 2.0.8 by default when installing or modifying installed packages
trac_osgeo4w at osgeo.org
Mon Apr 14 10:29:41 PDT 2014
packages
Reporter: saultdon | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords:
Comment(by saultdon):
There's an option in the configuration for Processing that looks like it's
already updated to use SAGA 2.1.0. Because SAGA tools are running in the
processing toolbox fine without error. I wonder if there are specific SAGA
2.1.0 tools that won't run in processing?
When a user has the old saga version (<2.1), they actually have to go into
the Processing "providers" portion and check "Enable SAGA 2.0.8
compatibility". This is what's needed with the current OSGeo4W installer.
[[Image(http://i.imgur.com/WRP7I19.png)]]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/400#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
