[Osgeo4w-trac] [osgeo4w] #399: [setuptools] easy_install fails with "failed to create process."
trac_osgeo4w at osgeo.org
Tue Jan 7 11:05:51 PST 2014
Reporter: saultdon | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: setuptools
Comment(by jef):
Replying to [comment:2 saultdon]:
> Replying to [comment:1 jef]:
> > Please provide sample output.
I was thinking of something like:
C:\OSGeo4W64>easy_install pypihello
Searching for pypihello
Reading https://pypi.python.org/simple/pypihello/
Best match: pypiHello 1.2
Downloading
https://pypi.python.org/packages/source/p/pypiHello/pypiHello-1.2.zip#md5=01f698cfbdbb8c0b5494c54eb53b065a
Processing pypiHello-1.2.zip
Writing c:\users\jef~1.nor\appdata\local\temp\easy_install-
i8hxfg\pypiHello-1.2\setup.cfg
Running pypiHello-1.2\setup.py -q bdist_egg --dist-dir
c:\users\jef~1.nor\appdata\local\temp\easy_install-i8hxfg\pypiHello-1.2
\egg-dist-tmp-2eicvc
zip_safe flag not set; analyzing archive contents...
Adding pypihello 1.2 to easy-install.pth file
Installed c:\osgeo4~1\apps\python27\lib\site-
packages\pypihello-1.2-py2.7.egg
Processing dependencies for pypihello
Finished processing dependencies for pypihello
C:\OSGeo4W64>
As you can see it works fine here.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/399#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
