[Osgeo4w-trac] [osgeo4w] #426: OSGeo4W-64bit: qgis 2.4 - GRASS data can't be loaded
trac_osgeo4w at osgeo.org
Mon Jul 7 00:39:49 PDT 2014
Reporter: hellik | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: GRASS
from the ML:
http://lists.osgeo.org/pipermail/osgeo4w-dev/2014-July/002764.html
>> warning: projection can't be determined
>> modul can't be executed
>> command C:/OSGEO~1/apps/qgis/./grass/modules/qgis.g.info info=proj
>> <br><br>
>> any idea?
>Not really. I can open the gtopo30 map from the qgis_sample_data set
just
>fine.
ok, it seems the underlying problem is in a broken OSGeo4W-GRASS6.4.3-5
64bit.
I can start a GRASS session only in text mode because g.proj (and some
other
modules, e.g. g.region, g.setproj) seems to be broken in
OSGeo4W-GRASS6.4.3-5 64 bit.
in a GRASS session in text mode I can start the module GUI e.g. by
GRASS 6.4.3 (nc_spm_08)> g.mlist --ui
or get the manual by
GRASS 6.4.3 (nc_spm_08)> g.mlist --help
Beschreibung:
Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten
Datentyps
und verwende optional ein Suchmuster.
Schlüsselwörter:
Allgemein, Kartenverwaltung
but I can not do this for g.proj, g.region, g.setproj; therefore the QGIS
error:
>> <br><br>
as the underlying GRASS module isn't working correctly.
tested on 2 different win boxes.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/426>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
