[Osgeo4w-trac] [osgeo4w] #420: qgis-common.bat fails during postinstall
trac_osgeo4w at osgeo.org
Mon Jul 7 02:42:14 PDT 2014
Reporter: jphespanha | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Installer
Version: | Resolution: fixed
Keywords: |
Comment(by hellik):
Replying to [comment:13 hellik]:
> Replying to [comment:11 jef]:
> > Replying to [comment:10 hellik]:
> > > I've checked, both ms 64bit runtimes (2008, 2010) are installed on
my box.
> >Did you check with depends
> opening crssync in dependency walker:
> Error: At least one required implicit or forwarded dependency was not
found.
> QGIS_CORE.DLL, GDAL111.DLL, QTCORE4.DLL
> but maybe it's because to be outside of a OSGeo4W session (?)
ok manually added search path of the 3 dll's to the dependency walker test
(C:\OSGeo4W64\bin and C:\OSGeo4W64\apps\qgis\bin), attached the log of
this test.
if I read the dependency walker correctly, there maybe some issues with:
- ZLIB1.DLL (in OGDI.DLL and QTCORE4.DLL)
- XERCES-C_3_1.DLL (in GDAL111.DLL; msvcr90.dll)
- ICONV.DLL (msvcr80.dll)
- SQLITE3.DLL (in QGIS_CORE.DLL, GDAL111.DLL, )
- LIBCURL.DLL (in GDAL111.DLL)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:15>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
