[Osgeo4w-trac] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Mon May 26 15:14:25 PDT 2014
Reporter:  hellik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  R
Comment(by hellik):
 Replying to [comment:2 hellik]:
 > any chance to add these helpful files in OSGeo4W? what would be the next
 steps to do?
 any opinion? any objections? any discussion? any suggested steps how to
 proceed?
 locally added C:\OSGeo4W\etc\ini\rbatchfiles.bat
 SET PATH=%PATH%;%OSGEO4W_ROOT%\apps\rbatchfiles
 in the OSGeo4W-command line:
 OSGEO4W home is C:\OSGeo4W\
                    -={ OSGeo4W Shell Commands }=-
        apt-r1193M           las2txt-old          rpcgen
        avcexport            las2txt              rpcinfo
        avcimport            lasblock             SFXWiz32
        bc                   lasinfo-old          tclsh
        bmp2tiff             lasinfo              tclsh85
        cs2cs                lasmerge             testepsg
        curl                 listgeo              textreplace
        dc                   nad2bin              thumbnail
        dllupdate            ncdump               tiff2bw
        fax2ps               ncgen                tiff2pdf
        fax2tiff             nearblack            tiff2ps
        funzip               nircmd               tiff2rgba
        gdaladdo             nircmdc              tiffcmp
        gdalbuildvrt         ogdi_import          tiffcp
        gdaldem              ogdi_info            tiffcrop
        gdalenhance          ogr2ogr              tiffdither
        gdalinfo             ogrinfo              tiffdump
        gdallocationinfo     ogrlineref           tiffinfo
        gdalmanage           ogrtindex            tiffmedian
        gdalserver           opj_compress         tiffset
        gdalsrsinfo          opj_decompress       tiffsplit
        gdaltindex           opj_dump             ts2las
        gdaltransform        osgeo4w-setup-work   txt2las
        gdalwarp             osgeo4w-setup        unzip
        gdal_contour         pal2rgb              unzipsfx
        gdal_grid            portmap              uzexampl
        gdal_rasterize       ppm2tiff             w9xpopen
        gdal_translate       proj                 wish
        geod                 psql                 wish85
        geotifcp             pylupdate4           xmlcatalog
        gif2tiff             pyrcc4               xmllint
        gltpd                python               xxmklink
        GPSBabel             pythonw              zip
        gswin32c             qgis-bin             zipcloak
        iconv                qgis-browser-bin     zipinfo
        las2las-old          ras2tiff             zipnote
        las2las              raw2tiff             zipsplit
        las2ogr              rgb2ycbcr
        apt-dev           gdal_edit         o4w_env
        apt               gdal_fillnodata   pct2rgb
        epsg_tr           gdal_merge        ps2pdf
        esri2wkt          gdal_polygonize   ps2pdf12
        gcps2vec          gdal_proximity    ps2pdf13
        gcps2wld          gdal_retile       ps2pdf14
        gdal2tiles        gdal_sieve        ps2pdfxx
        gdal2xyz          grass64           pyuic4
        gdalchksum        grass64svn        qgis-browser
        gdalcompare       grass71svn        qgis
        gdalident         gssetgs           rgb2pct
        gdalimport        liblas            setup-test
        gdalmove          make-bat-for-py   setup
        gdal_auth         mkgraticule
        gdal_calc         o-help
 GDAL 1.11.0, released 2014/04/16
 C:\>R
 R version 3.0.3 (2014-03-06) -- "Warm Puppy"
 Copyright (C) 2014 The R Foundation for Statistical Computing
 Platform: x86_64-w64-mingw32/x64 (64-bit)
 R ist freie Software und kommt OHNE JEGLICHE GARANTIE.
 Sie sind eingeladen, es unter bestimmten Bedingungen weiter zu verbreiten.
 Tippen Sie 'license()' or 'licence()' für Details dazu.
 R ist ein Gemeinschaftsprojekt mit vielen Beitragenden.
 Tippen Sie 'contributors()' für mehr Information und 'citation()',
 um zu erfahren, wie R oder R packages in Publikationen zitiert werden
 können.
 Tippen Sie 'demo()' für einige Demos, 'help()' für on-line Hilfe, oder
 'help.start()' für eine HTML Browserschnittstelle zur Hilfe.
 Tippen Sie 'q()', um R zu verlassen.
 > q()
 Workspace sichern? [y/n/c]: n
 C:\>
 everything works without any problem.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/413#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
