[Osgeo4w-trac] [osgeo4w] #420: qgis-common.bat fails during postinstall
trac_osgeo4w at osgeo.org
Tue May 27 09:05:43 PDT 2014
Reporter: jphespanha | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords:
Comment(by jphespanha):
Replying to [comment:5 jef]:
> Replying to [comment:4 jphespanha]:
> > Sure that this path is OK?
> > set QGIS_PREFIX_PATH=C:/OSGEO4~1/apps/qgis
> You tell me. Doesn't "C:/OSGEO4~1/apps/qgis" take you to the qgis
directory?
> I suspect there is a side by side configuration error. Please check
eventlog is you can spot any, use [http://www.dependencywalker.com/
dependency walker] find details about it. I still think the server is
just missing some ''Microsoft Visual C++ Redistributable Package''. It
would be nice if you could identify which particular one it is.
There is no problem with the path. I just find it confusing; in windows
should be "C:\OSGEO4~1\apps\qgis", but it works nevertheless.
And you are right with the "SidebySide" error. I checked the application
event log at the server, and spotted this message:
"Activation context generation failed for "C:\OSGEO4~1\bin\SSLEAY32.dll".
Dependent Assembly
Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"
could not be found. Please use sxstrace.exe for detailed diagnosis."
I will try the "dependency walker", but maybe there is already sufficient
info to solve the situation.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
