[Osgeo4w-trac] [osgeo4w] #420: qgis-common.bat fails during postinstall
OSGeo4W trac_osgeo4w at osgeo.org
Thu Nov 27 16:58:17 PST 2014
Reporter:  jphespanha  |        Owner:  osgeo4w-dev@…
    Type:  defect      |       Status:  closed
Priority:  major       |    Component:  Installer
 Version:              |   Resolution:  fixed
Keywords:              |
Comment(by dncpax):
 I am experiencing the same problem.
 Win7 x64.
 crssync.exe fails because windows\system32 has some other dll's. I have to
 copy these libs from osgeo4w\bin to apps\qgis (whre crssync.exe is):
 iconv.dll
 libeay32.dll
 ssleay32.dll
 Then I can run qgis-common.bat.
 It seems to be very common to have these libs under windows\system32. To
 avoid loading these you have to have the correct version in the same dir
 as the executable, in this case crssync. Don't know if you want to reopen.
 But this will happen to a lot of folks...
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:23>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
