[Osgeo4w-trac] [osgeo4w] #455: Driver conflicts FileGDB vs	OpenFileGDB
    trac_osgeo4w at osgeo.org
    Tue Feb  3 08:39:08 PST 2015
Reporter:  pelord  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:
 I use OSGEO4W online installer to manage my GDAL/OGR installation. I use a
 GDB 9.3 to test this issue, with a geometric layer.
 When the ESRI FileGDB driver is not installed, the OpenFileGDB driver open
 correctly the GDB.
 When I install ESRI FileGDB driver, this message is shown:
 ogrinfo gdb93.gdb
 ERROR 1: Error: Failed to open Geodatabase (This release of the
 GeoDatabase? is e ither invalid or out of date.)
 FAILURE: Unable to open datasource `gdb93.gdb' with the following drivers.
 -> FileGDB
 -> ESRI Shapefile
 -> MapInfo? File
 When the FileGDB driver is installed as a plugin, the actual, the order is
 actually OpenFileGDB and the FileGDB is not respected.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/455>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
