[Osgeo4w-trac] [osgeo4w] #517: OGDI VRF not loading VPF data using latest OSGeo4W x86_64
    trac_osgeo4w at osgeo.org
    Wed Aug  3 10:33:01 PDT 2016
Reporter:  blsherrill  |      Owner:  osgeo4w-dev@…
    Type:  defect      |     Status:  new
Priority:  major       |  Component:  Package
 Version:              |   Keywords:
 Hello,
 I recently switched from 32 to 64 bit GDAL libraries (using OSGeo4W
 binaries), and I've been unable to load VPF data via OGR/OGDI using the
 latest x86_64 build.  I confirmed that the latest x86 build correctly
 loads VPF data (using ogr_info.exe), while the x86_64 build does not.
 I get the following message:
 ECSERROR: Could not find the dynamic library "vrf"
 Vrf.dll is in the same directory and I confirmed that the dlls are in fact
 x64.  I am able to load my application as an 64 bit process, but the VPF
 data does not load using OGR.
 Perhaps there is a linking issue with the vrf library?  Or does OGDI not
 support VRF for x64?
 Thanks,
 blsherrill
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/517>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
