[Osgeo4w-trac] [osgeo4w] #466: Python stopped working when using python gdal_calc and band.ReadAsArray() on Windows
    trac_osgeo4w at osgeo.org
    Tue Aug 30 02:12:08 PDT 2016
on Windows
Reporter:  miro         |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  gdal python  |
Comment (by ascarth):
 This seems to be an issue with how GDAL has been built for OSGeo4W, or the
 Python version, but not with GDAL itself. I have found that python will
 crash using the OSGeo4W Shell, but not when using GDAL installed through
 [https://www.continuum.io/downloads Conda]. Both installations are using
 GDAL 2.1.0. The only other difference is that Conda uses Python 2.7.12 and
 OSGeo4W uses Python 2.7.5
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/466#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
