[Osgeo4w-trac] [osgeo4w] #293: update gdal dependencies (netcdf, hdf5)
OSGeo4W trac_osgeo4w at osgeo.org
Sun Dec 4 21:29:07 PST 2016
Reporter:  jef      |       Owner:  osgeo4w-dev@…
    Type:  task     |      Status:  new
Priority:  major    |   Component:  Package
 Version:           |  Resolution:
Keywords:  netcdf4  |
Comment (by dr):
 Trying to convert NetCDF dataset to GeoTIF and get the following error
 (GDAL 2.1.1, NetCDF 4.3.0):
 gdalwarp -ts 360 140
 netcdf:2016121233557Forest_Aboveground_Biomassv3.nc:Forest_Aboveground_Biomass_v3
 output.tif
 ERROR 1: netCDF scanline fetch failed: #-101 (NetCDF: HDF error)
 ERROR 1:
 Biomass_v3, band 1: IReadBlock failed at X offset 0, Y offset 0
 ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
 But on the Linux (GDAL 2.1.0, NetCDF 4.4.0) all works fine.
 Test file:
 https://drive.google.com/file/d/0B6TJ2VnOYaa1RkNGbzFLU3dqalE/view?usp=sharing
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/293#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
