[Osgeo4w-trac] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Mon Dec 12 10:20:54 PST 2016
Reporter:  hellik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  R            |
Comment (by hellik):
 Replying to [comment:31 hellik]:
 > Replying to [comment:30 jef]:
 > > Replying to [comment:29 hellik]:
 > > > any hints?
 > > Access the url using a browser.
 > ok thanks, done.
 the output of osgeo4w-promote.sh
 --- setup.ini.prev      2016-12-12 10:12:31.000000000 -0800
 +++ setup.ini   2016-12-12 10:12:31.000000000 -0800
 @@ -3,7 +3,7 @@
  # See http://cygwin.com/setup.html for details.
  arch: x86
 -setup-timestamp: 1481530023
 +setup-timestamp: 1481566157
  @ agg-devel
  sdesc: "AGG rendering library (development)"
 @@ -2875,6 +2875,12 @@
  install: x86/release/qt/qt4/qwt-libs-qt4/qwt-libs-qt4-6.0.2-1.tar.bz2
 306829 2a8cbc63a581882b5db9010d1bbecd7e
  source: x86/release/qt/qt4/qwt-libs-qt4/qwt-libs-qt4-6.0.2-1-src.tar.bz2
 2197 4eae9be815016415611fd0b176443352
 +@ rbatch
 +sdesc: "Windows batchfiles for use with R"
 +ldesc: "Windows batchfiles for use with R"
 +category: Libs Commandline_Utilities
 +version: r149
  @ regex-devel
  sdesc: "Regex libaray (source/header) (development)"
  ldesc: "Regex libaray (source/header) (development)"
 @@ -3,7 +3,7 @@
  arch: x86_64
 -setup-timestamp: 1481530024
 +setup-timestamp: 1481566159
  @ alkis-import
  sdesc: "norGIS ALKIS Import"
 @@ -2141,6 +2141,12 @@
  install: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-qt4-5.2.3-1.tar.bz2
 261328 4a732090f019931026aa4fe478670ebd
  source: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-
 qt4-5.2.3-1-src.tar.bz2 3211 5259de566c37bf132c7a60783af575cf
 +@ rbatch
 +version: r149
  @ regex-devel
  sdesc: "XDR library (Development)"
  ldesc: "XDR library (Development)"
 it seems now to be in setup.ini; anything else to do that it is promoted
 to be downloadable.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/413#comment:32>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
