[Osgeo4w-trac] [osgeo4w] #487: cs2cs in proj 4.9.2-2 does not work
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 29 05:00:25 PST 2016
Reporter:  nicothom  |      Owner:  osgeo4w-dev@…
    Type:  defect    |     Status:  new
Priority:  major     |  Component:  Package
 Version:            |   Keywords:
 cs2cs in proj 4.9.2-2 does not work.
 When running cs2cs command in OSGeo4W Shell, nothing happen, the shell is
 blocked, whereas with the version 4.9.2-1 cs2cs runs normally and returns
 the basic help:
 >cs2cs
 Rel. 4.9.2, 08 September 2015
 usage: cs2cs [ -eEfIlrstvwW [args] ] [ +opts[=arg] ]
                    [+to [+opts[=arg] [ files ]
 System info:
 win7 Pro SP1 64bits with i7-4800MQ @ 2.7 GHz and 16 Go RAM
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/487>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
