[Osgeo4w-trac] [osgeo4w] #482: setup cygwin repository
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jan 20 09:08:27 PST 2016
Reporter:  tylerkelly13    |       Owner:  osgeo4w-dev@…
    Type:  task            |      Status:  new
Priority:  minor           |   Component:  Installer
 Version:  1.0             |  Resolution:
Keywords:  setup; install  |
Comment (by maphew):
 You can have the two installed side by side (c:\cygwin, c:\osgeo4w) and
 for those occasions when you need to use a cygwin tool add the folder to
 path (or call tool directly).
 set path=%path%;c:\cygwin\bin
 some_cygwin_tool_cmd_here
 However most everything I used to reach in to Cygwin for is now part of
 the Msys package in Osgeo4w.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/482#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
