[Osgeo4w-trac] [osgeo4w] #466: Python stopped working when using python gdal_calc and band.ReadAsArray() on Windows
trac_osgeo4w at osgeo.org
Thu Sep 1 14:06:55 PDT 2016
on Windows
Reporter: miro | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal python |
Comment (by mcserep):
Replying to [comment:7 ascarth]:
> This seems to be an issue with how GDAL has been built for OSGeo4W, or
the Python version, but not with GDAL itself. I have found that python
will crash using the OSGeo4W Shell, but not when using GDAL installed
through [https://www.continuum.io/downloads Conda]. Both installations are
using GDAL 2.1.0. The only other difference is that Conda uses Python
2.7.12 and OSGeo4W uses Python 2.7.5
Since this is the website of OSGeo4W, I think this is still a valid and
urgent bug report, and it is really disappointing how it lacks the
required attention. By the way I faced the same bug when I used the GDAL
binaries from [http://gisinternals.com/ GISInternals].
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/466#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
