[Osgeo4w-trac] [osgeo4w] #481: The _imaging C module is not installed on QGIS 2.12.x Windows 32 bits
    trac_osgeo4w at osgeo.org
    Thu Apr 27 08:44:43 PDT 2017
Reporter:  jhemmi                    |       Owner:  osgeo4w-dev@…
    Type:  defect                    |      Status:  new
Priority:  minor                     |   Component:  Installer
 Version:                            |  Resolution:
Keywords:  QGIS Matplotlib _imaging  |
Comment (by jakosek):
 As I remember problem with PIL was not missing files, but precompiled
 module with bad paramerets.
 Main problem is pointed on stackoverflow:
 The freetype C library references a debug CRT that is not available on all
 machines. You can easily patch the _imagingft.pyd file with a hex editor.
 Pillow modules work on all tested computers.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/481#comment:10>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
