[Osgeo4w-trac] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
trac_osgeo4w at osgeo.org
Sun Dec 10 10:08:28 PST 2017
Reporter: hellik | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Keywords: las
lasinfo --help in the ''OSGeo4W-64 bit-shell'' crashes with:
procedure entry point "?get_error at LASzipper@@QEBAPEBDXZ" couldn't find in
the DLL "C:\OSGEO$~1\bin\liblas.dll".
starting a dependency walker session in the ''OSGeo4W-64 bit-shell'' shows
following issues:
Error: At least one required implicit or forwarded dependency was not
found.
Error: At least one module has an unresolved import due to a missing
export function in an implicitly dependent module.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
having a closer look into the dependency walker results, it seems the isse
seems to be within ''laszip.dll''
??0LASunzipper@@QEAA at XZ
??0LASzip@@QEAA at XZ
??0LASzipper@@QEAA at XZ
??1LASunzipper@@QEAA at XZ
??1LASzip@@QEAA at XZ
??1LASzipper@@QEAA at XZ
?close at LASunzipper@@QEAA_NXZ
?get_error at LASunzipper@@QEBAPEBDXZ
?get_error at LASzip@@QEBAPEBDXZ
?get_name at LASitem@@QEBAPEBDXZ
?open at LASunzipper@@QEAA_NAEAV?$basic_istream at DU?$char_traits at D@std@@@std@@PEBVLASzip@@@Z
?open at LASzipper@@QEAA_NAEAV?$basic_ostream at DU?$char_traits at D@std@@@std@@PEBVLASzip@@@Z
?pack at LASzip@@QEAA_NAEAPEAEAEAH at Z
?read at LASunzipper@@QEAA_NPEBQEAE at Z
?seek at LASunzipper@@QEAA_NI at Z
?setup at LASzip@@QEAA_NEGG at Z
?unpack at LASzip@@QEAA_NPEBEH at Z
?write at LASzipper@@QEAA_NPEBQEBE at Z
attachted the dependency walker profiling output.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
