[Osgeo4w-trac] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
    trac_osgeo4w at osgeo.org
    Sun Dec 17 12:02:03 PST 2017
Reporter:  hellik    |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:            |  Resolution:
Keywords:  las       |
Comment (by hellik):
 Replying to [comment:7 jef]:
 > Replying to [comment:6 hellik]:
 > > tried with the OSGEo4W setup here, can't revert back to the earlier
 version.
 > Now you can.
 http://download.osgeo.org/osgeo4w/x86_64/release/laszip/setup.hint
 sdesc: "The LASzip compression library"
 ldesc: "LASzip is a compression library for ASPRS LAS LiDAR data"
 maintainer: hobu
 category: Libs Commandline_Utilities
 requires: shell msvcrt2015
 prev: 2.2.0-3
 curr: 3.1.1-3
 I've seen that you changed the setup.hint.
 IMHO it doesn't solve the fundamental issue regarding compiling/runtime in
 all the user's OSGeo4W stack.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
