[Osgeo4w-trac] [osgeo4w] #536: QGIS install with OSGeo4W issue
trac_osgeo4w at osgeo.org
Tue Jun 27 02:45:57 PDT 2017
Reporter: Guillaume Huby | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: QGIS, QGIS-Common |
Comment (by Guillaume Huby):
Good idea to have a look at all packages, I found a package named "Gdal
2.0.1" that was not selected.
I selected it and proceed to install.
I had a new error message on qgis-common package (approximate translation
from french):
"Entry point of procedure ?mRunningFromBuildDir21810 at QgsApplication@@0_NA
could not be found in library of dynamic links
C:\OSGEO4~1\apps\qgis\crssync.exe".
Yet I could start QGIS but I have an error message:
"Impossible to load PyQGIS [...]".
UI starts and displays "QGIS 2.18.7" instead of QGIS 2.18.10.
I selected (I list only main packages, the list is long):
* gdal 2.2.0-6;
* setup OSGeo4W 1.0.7-13;
* shell OSGeo4W 1.0.1-2;
* grass 7.2.1-1;
* grass6 6.4.3-5;
* qgis 2.18.10-1;
* saga 2.1.2-2;
* saga-ltr 2.3.2-1;
* Many gdal packages with release 2.2.0-6;
* Many QGIS packages with release 2.18.10-1.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/536#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
